时间:2011-07-01 10:42:46 作者:Intersil 来源:ISL97684
Intersil公司的ISL97684是用于中等尺寸TFT-LCD背光的四路LED驱动器,输入电压低到4V,输出电压高达45V.还提供8位PWM调光,在时的线性度低至0.009%,或30kHz时为1.35%,主要应用在平板PC和笔记本电脑显示LED背光,PMP LED背光.本文介绍了ISL97684主要特性, 方框图,以及单电源,双电源应用电路和PWM调光应用电路.
The ISL97682, ISL97683, ISL97684 are Intersil’s highly integrated 2-3-4-channels LED drivers that are suitable for medium size TFT-LCD backlights. These parts can drive multiple channels of LEDs from inputs as low as 4V to outputs of up to 45V. They can also operate from inputs as low as 3V to outputs of up to 26.5V in bootstrap configuration.
The ISL97682, ISL97683, ISL97684 feature optional channels phase shift control. This feature is used to minimize the input, output ripple characteristics and load transient, which help eliminate or reduce the video and audio noise interference from the backlight driver operation.
The ISL97682, ISL97683, ISL97684 offer 8-bit PWM dimming for systems that need frequency tuning flexibility. With the unique adaptive boost switching architecture, the ISL97682, ISL97683, ISL97684 also offer Direct PWM dimming with output, which follows input and achieves linearity as low as 0.009% at 200Hz or 1.35% at 30kHz.
分享到:
