时间:2011-06-07 10:50:34 作者:Fairchild 来源:FDMF6707
Fairchild公司的FDMF6707是Generation II XS™ DrMOS器件,在6x6mm尺寸内可提供94%的效率,可处理高达50A的大电流,具有三态3.3V PWM输入驱动器,开关频率可高达1MHz,主要用在高性能游戏主板,刀形服务器,V-Core和无V-Core DC/DC转换器,台式计算机和工作站电源,大电流DC/DC POL转换器以及网络和通信微处理器电源.本文介绍了FDMF6707主要特性和优势,方框图, 典型应用框图, 电源损耗测量框图和PCB布局图.
Fairchild Semiconductor’s Generation II XS™ DrMOS Devices Offer 94% Efficiency in 6mm x 6mm Form Factor
The XS™ DrMOS family is Fairchild’s next-generation, fully optimized, ultra-compact, integrated MOSFET plus driver power stage solution for high-current, highfrequency, synchronous buck DC-DC applications. The FDMF6707B integrates a driver IC, two power MOSFETs, and a bootstrap Schottky diode into a thermally enhanced, ultra-compact 6x6mm PQFN package.
With an integrated approach, the complete switching power stage is optimized for driver and MOSFET dynamic performance, system inductance, and power MOSFET RDS(ON). XS™ DrMOS uses Fairchild’s highperformance PowerTrench® MOSFET technology, which dramatically reduces switch ringing, eliminating the snubber circuit in most buck converter applications.
分享到:
