IR IRS2092 1700W单路D类音频功率放大方案
关键词:消费类电子 D类放大器
时间:2011-06-01 10:10:12       作者:IR       来源:IRS2092
IR公司的 IRS2092是集成了PWM调制器和保护的高压高性能D类音频放大器,工作频率高达800kHz,±100 V额定电压是可提供500W输出功率,主要用在家庭影院,密你立体声系统,通用音频放大器等。本文介绍IRS2092主要特性,方框图,典型连接图,典型应用电路图以及1700W单路D类音频功率放大器框图,主要特性,电路图和材料清单。
The IRS2092 is a high voltage, high performance Class D audio amplifier driver with PWM modulator and protection.
In conjunction with two external MOSFET and a few external components, a complete Class D audio amplifier with protection can be realized.
International Rectifier’s proprietary noise isolation technology allows high current gate drive stage and high speed low noise error amplifier reside on a single small silicon die.Open elements of PWM modulator section allow flexible PWM topology implementation.
IRS2092主要特性:
• Integrated analog input Class D audio amplifier driver in a small 16 pin package
• Floating inputs enable easy half bridge implementation
• Programmable bidirectional over-current protection with self-reset function
• Programmable preset deadtime for improved THD performances
• Start and stop click noise reduction
• High noise immunity
查看全文
