时间:2011-05-03 09:59:06 作者:Powerint 来源:TOP265KG
Powerint公司的DER275 30W高效电源解决方案是采用TOPSwitch-JX系列的TOP265KG,它集成了725V功率MOSFET,高压开关电流源,多模式PWM控制,振荡器,热关断电路,故障保护和其它控制电路。TOPSwitch-JX系列可提供10W-245W输出功率,265 VAC时无负载功耗低于100mW,具有多种扩展保护功能,主要用在笔记本电脑,通用适配器,打印机,LCD监视器,STB,PC或LCD TV待机和音频放大器。本文介绍了TOPSwitch-JX系列产品亮点,方框图,高效19V/65W和12V/30W的通用输入反激电源电路图,以及采用TOPSwitchTM-JX TOP265KG的高效30W电源参考设计主要指标,电路图,材料清单和PCB布局图。
TOPSwitch-JX cost effectively incorporates a 725 V power MOSFET, high-voltage switched current source, multi-mode PWM control, oscillator, thermal shutdown circuit, fault protection and other control circuitry onto a monolithic device.
TOPSwitch-JX系列产品亮点:
EcoSmart – Energy Efficient
• Ideal for applications from 10 W to 245 W
• Energy efficient over entire load range
• No-load consumption below 100 mW at 265 VAC
• Up to 750 mW standby output power for 1 W input at 230 VAC
High Design Flexibility for Low System Cost
• Multi-mode PWM control maximizes efficiency at all loads
• 132 kHz operation reduces transformer and power supply size
• 66 kHz option for highest efficiency requirements
分享到:
