Linear公司的LTC4000是高压高性能电池充电控制器,输入和输出电压宽达3V到60V,输入和充电电流精度在±1%,可编程浮电压精度±0.25%,可选择的定时器和终止充电电流,采用NTC热电阻的温度补偿充电,自动再充电,不良电池检测和用于深度放电电池的C/10涓流充电以及状态指示输出.主要用在大功率电池充电系统,高性能手持仪表,笔记本/亚笔记本电脑等.本文介绍了LTC4000主要特性,方框图, 用于三个LiFePO4电池的48-10.8V/10A降压充电器电路图以及用于单个和多个锂离子电池充电器电路图.
The LTC®4000 is a high voltage, high performance controller that converts many externally compensated DC/DC power supplies into full-featured battery chargers. Features of the LTC4000’s battery charger include: accurate (±0.25%) programmable float voltage, selectable timer or current termination, temperature qualified charging using an NTC thermistor, automatic recharge, C/10 trickle charge for deeply discharged cells, bad battery detection and status indicator outputs. The battery charger also includes precision current sensing that allows lower sense voltages for high current applications.
分享到:
