Infineon 公司XE166 系列是16位实时信号控制器,具有高性能的5级流水线的CPU,80MHz CPU的指令周期为12.5ns,工作电压3.0 V 到5.5 V,多达75个GPIO主要用在汽车,工业,海量存储和有线与无线通信设备.本文介绍了XE166 系列主要特性,方框图,CPU方框图,以及开发板XE166 Easy Kit主要特性,方框图,元件布局图和电路图.
XE164:16-Bit Single-Chip Real Time Signal Controller
The XE164 series of real time signal controllers is a part of the Infineon XE166 Family of full-feature single-chip CMOS microcontrollers. These devices extend the functionality and performance of the C166 Family in terms of instructions (MAC unit), peripherals, and speed. They combine high CPU performance (up to 80 million instructions per second) with extended peripheral functionality and enhanced IO capabilities. Optimized peripherals can be adapted flexibly to meet the application requirements. These derivatives utilize clock generation via PLL and internal or external clock sources. Onchip memory modules include program Flash, program RAM, and data RAM.
XE166 系列主要特性:
For a quick overview and easy reference, the features of the XE164 are summarized here.
• High-performance CPU with five-stage pipeline
– 12.5 ns instruction cycle at 80 MHz CPU clock (single-cycle execution)
分享到:
