Cymbet 公司的CBC915是 EnerChip EP能量处理器,采用先进的最大峰值功率跟踪(MPPT)算法,适用于光,振动,热和RF等能量收集传感器,具有温度补偿的充电控制,内置了能量存储保护,转换电压可调整和低待机功耗,工作温度-20℃ 到 +70℃。本文介绍了CBC915主要特性,能量处理器应用电路,EnerChip™ EP通用能量收集评估套件CBC-EVAL-09主要特性,CBC-EVAL-09演示板方框图,电路图和材料清单。
CBC915 EnerChip™ EP Energy Processor
Many new energy harvesting based products can be enabled by the EnerChip EP:
•Various ambient energy sources can be harvested to power new designs using : Photo Voltaic Cells,Piezoelectric vibration harvesters, Thermoelectric cells, Electromagnetic harvesters, RF Induction charging.
•Designs can use ultra low power by leveraging the Maximum Peak Power Tracking EnerChip EP capabilities
•The power management communications interface to the system MCU can be used to create “Energy Aware” systems
•Input power measurement and status reporting
•Advanced energy storage management
• Advanced energy storage management
• Uses digital power controls
分享到:
