时间:2011-03-01 10:21:39 作者:IR 来源:IR3477
IR公司的IR3477 SupIRBuck是容易使用的高效全集成DC/DC电压稳压器,可提供精确控制的15A输出电压,输入电压从3V到27V,输出电压从0.5V到12V,不需要补偿回路,在非常低输出电流时有极好的效率,可编程开关频率和蔼软起动,主要用在笔记电脑和台式计算机,消费类电子如STB,LCD,TV和打印机等,12V和24V分布电源,通用POL DC/DC转换器以及游戏机和图像卡等.本文介绍了IR3477主要特性,方框图,典型应用电路,演示板电路图和材料清单,以及IRDC3477评估板主要特性,电路图和材料清单.
The IR3477 SupIRBuckTM is an easy‐to‐use, fully integrated and highly efficient DC/DC voltage regulator. The onboard constant on time hysteretic controller and MOSFETs make
IR3477 a space‐efficient solution that delivers up to 15A of precisely controlled output voltage.
Programmable switching frequency, soft start, and thermally compensated over current protection allows for a very flexible solution suitable for many different applications and an ideal choice for battery powered applications.
Additional features include pre‐bias startup, very precise 0.5V reference, under/over voltage shutdown, thermal protection, power good output, and enable input with voltage monitoring capability.
IR3477主要特性:
Input Voltage Range: 3V to 27V
Output Voltage Range: 0.5V to 12V
Continuous 15A Load Capability
Constant On‐Time Control..
分享到:
