Maxim公司的71M6543F/71M6543H是第四代多相电表系统级芯片(SoC),具有5MHz的8051兼容的MPU内核,带数字温度补偿的低功耗实时时钟(RTC),闪存和LCD驱动器,2000:1电流范围内精度为0.1%,性能超过IEC 62053/ANSI C12.20标准,集成了22位Delta-Sigma ADC,具有七个传感器输入,数字温度补偿,精密的基准电源,以及32位计算引擎(CE),多达4个脉冲输出, 46-64Hz火线频率校准,外接元件很少.本文介绍了71M6543F/71M6543H主要特性, 功能方框图, 智能电表方框图以及两种系统方框图和推荐的外接元器件.
The 71M6543F/71M6543H are Teridian’s 4th-generation polyphase metering systems-on-chips (SoCs) with a 5MHz 8051-compatible MPU core, low-power real-time clock (RTC) with digital temperature compensation, flash memory, and LCD driver. Our Single Converter Technology® with a 22-bit delta-sigma ADC, seven analog inputs, digital metrology temperature compensation, precision voltage reference, and a 32-bit computation engine (CE) supports a wide range of metering applications with very few external components.
分享到:
