TI bq25046 5W无接触充电和管理解决方案
关键词:电源管理 DC/DC转换器 充电器 LDO
时间:2011-01-10 10:57:35       作者:TI       来源:bq25046
TI 公司的bq25046 是5W(1.1A/5V)无接触充电应用的电源集成电路,适用于有线和无线电源应用,具有5V稳压输出和集成的3.3V/15mA LDO,输入电压额定值30V,15V过压保护阈值, 能给MSP430BQ1010 MCU直接供电,主要用在无线电源,智能手机,PDA,MP3播放器和低功率手持设备.本文介绍了bq25046主要特性,方框图,典型应用和无线电源系统方框图, 作无接触电源接收器的应用电路以及bqTESLA无线电源系评估套件HPA688EVM主要特性,电路图和材料清单(BOM).
bq25046:1.1A, Single-Input 5-V Power Supply IC for Contactless Charging Applications
The bq25046 is a highly integrated linear power supply IC targeted at both wired and wireless power applications. With an accurate 5-V regulated output and integrated 3.3-V LDO, the bq25046 is an ideal solution for wireless power supply solutions up to 5 W.
The bq25046 integrates several functions which enable a wireless charging solution within a small area and low component count. These include a 3.3-V LDO which drives an MSP430BQ1010 wireless controller, high-accuracy current sense for calculating receiver-side power usage, 100mA/400mA current limits enable robust communication at all load current levels, and integrated pass FET acts as load disconnect switch and 5-V regulator to protect downstream circuitry.
bq25046主要特性:
30V Input Rating, with 15V Over-Voltage Protection (OVP) Threshold
查看全文
