Maxim 公司的MAX34441是 PMBus五路电源管理器和智能风扇控制器,电源管理器能监视电源输出电压,用户编程的过压和欠压阈值。MAX34441具有PMBus兼容的命令接口,I2C/SMBus兼容的串行接口,不需要外接时钟,3.3V电源,主要用在网络交换/路由器,基站,服务器,智能电网系统和工业控制。本文介绍了MAX34441主要特性,方框图以及多个器件连接方框图和典型应用电路。
PMBus 5-Channel Power-Supply Manager and Intelligent Fan Controller
The MAX34441 is a complex system monitor that can manage up to five power supplies and a fan. The power-supply manager monitors the power-supply output voltage and constantly checks for user-programmable overvoltage and undervoltage thresholds. It can also margin the power-supply output voltage up or down to a user-programmable level. The margining is performed in a closed-loop arrangement whereby the device automatically adjusts a pulse-width-modulated (PWM) output and then measures the resultant output voltage. The power-supply manager can also sequence the supplies in any order at both power-up and power-down. With the addition of an external current-sense amplifier, the device can also monitor currents.
分享到:
