ADI 公司的ADRF6850是高度集成宽带(100MHz 到1000MHz)正交解调器,频率合成器和可变增益放大器(VGA),并集成了VCO,提供的频率分辨率优于1Hz,增益控制范围60dB,0dBm时的输入P1dB为+12dBm,输入IP3为+22.5dBm,工作电压3.15 V 到 3.45 V,主要用在宽带通信,蜂窝通信和卫星通信。本文介绍了ADRF6850主要特性,功能方框图和PCB电路图以及材料清单(BOM)。
The ADRF6850 is a highly integrated broadband quadrature demodulator, frequency synthesizer, and variable gain amplifier (VGA). The device covers an operating frequency range from 100 MHz to 1000 MHz for use in both narrow-band and wideband communications applications, performing quadrature demodu-lation from IF directly to baseband frequencies.
The ADRF6850 demodulator includes a high modulus fractional-N frequency synthesizer with integrated VCO, providing better than 1 Hz frequency resolution, and a 60 dB gain control range provided by a front-end VGA.
Control of all the on-chip registers is through a user-selected SPI interface or I2C interface. The device operates from a single power supply ranging from 3.15 V to 3.45 V.
ADRF6850主要特性:
IQ quadrature demodulator
Integrated fractional-N PLL and VCO
Gain control range: 60 dB
Input frequency range: 100 MHz to 1000 MHz
分享到:
