Powerint LNK605DG高效3.6W LED驱动方案(DER261)
关键词:电源管理 AC/DC转换器 LED驱动器
时间:2010-10-28 11:48:57       作者:Powerint       来源:LNK605DG
Powerint公司的LinkSwitch-II系列 LNK605DG集成了700V功率MOSFET,新颖的OM/OFF控制状态机,用于自偏压的高压开关电流源,逐个周期的电流限制以及延迟的热关断电路。由于不需要光耦合器和次级控制电路,因此大大地简化了低功率CV/CC充电器的设计。230VAC时无负载的功耗低于30mW,主要用于手机/无绳电话,PDA,MP3/手提音频设备的充电器,以及LED驱动器等。本文介绍了LinkSwitch-II系列 LNK605DG主要特性,功能方框图,高能效USB充电器电路图,无偏压电源的反激电源电路图以及采用LinkSwitchTM-II LNK605DG的高效(≥75%) 3.6W绝缘LED驱动器参考设计主编要特性与指标,电路图和材料清单(BOM)。
The LinkSwitch-II dramatically simplifies low power CV/CC charger designs by eliminating an optocoupler and secondary control circuitry. The device introduces a revolutionary control technique to provide very tight output voltage and current regulation, compensating for transformer and internal parameter tolerances along with input voltage variations.
The device incorporates a 700 V power MOSFET, a novel ON/OFF control state machine, a high voltage switched current source for self biasing, frequency jittering, cycle-by-cycle current limit and hysteretic thermal shutdown circuitry onto a monolithic IC.
LNK605DG 产品亮点:
Dramatically Simplifies CV/CC Converters
• Eliminates optocoupler and all secondary CV/CC control circuitry
• Eliminates all control loop compensation circuitry
查看全文
