ST STM32F100VBT6 32位MCU开发评估方案
关键词:工业控制 PLC HVAC 逆变器
时间:2010-10-26 11:54:06       作者:ST       来源:STM32F100VBT6
摘要: ST 公司的STM32F100VBT6采用ARM Cortex™-M3 32位RISC内核,工作频率24MHz,集成了高速嵌入式存储器(闪存高达128KB,SRAM高达8KB)以及各种增强外设和连接到两条APB总线的I/O.所有器件提供两个I2C,两个SPI,一个HDMI CEC和多达3个USART标致通信接口以及一个12位ADC,两个12位DAC和六个通用16位定时器和PWM定时器.主要用在控制和用户接口,医疗设备,PC和游戏机外设,GPS平台,工业应用,PLC,逆变器,打印机,视频通信和HVAC等.本文介绍了STM32F100VBT6主要特性, 方框图, 时钟树框图和电源框图以及STM32100B-EVAL评估板主要特性, 评估板硬件方框图和详细电路图.
STM32F100x4 STM32F100x6,STM32F100x8 STM32F100xB
Low & medium-density value line, advanced ARM-based 32-bit MCU with 16 to 128 KB Flash, 12 timers, ADC, DAC & 8 comm interfaces
The STM32F100xx value line family incorporates the high-performance ARM Cortex™-M3 32-bit RISC core operating at a 24 MHz frequency, high-speed embedded memories (Flash memory up to 128 Kbytes and SRAM up to 8 Kbytes), and an extensive range of enhanced peripherals and I/Os connected to two APB buses. All devices offer standard communication interfaces (up to two I2Cs, two SPIs, one HDMI CEC, and up to three USARTs), one 12-bit ADC, two 12-bit DACs, up to six general-purpose 16-bit timers and an advanced-control PWM timer.
查看全文
