Linear LTC5583双路6GHz RMS功率检测方案
关键词:通信技术 无线通信 LTE EDGE W-CDMA CDMA2000 TD-SCDMA WiMAX
时间:2010-10-09 09:58:50       作者:Linear       来源:LTC5583
Linear公司的LTC5583是匹配的双路6GHz RMS功率检测器,能测量两路AC信号,动态范围从-59dBm 到4dBm,频率范围从40MHz 到6GHz,整个温度范围精度为±0.5dB,两路的匹配输出小于1.25dB,快速响应时间,上升时间140ns,主要用在VSWR监视器,MIMO发送功率控制,基站功率放大器控制,发送和接收增益控制以及RF仪表.本文介绍了LTC5583主要特性,方框图, 单端输入配置和差分输入配置测试电路图以及单端输入配置图和差分输入配置图.
LTC5583 - Matched Dual-Channel 6GHz RMS Power Detector
The LTC5583 is a dual-channel RMS power detector, capable of measuring two AC signals with wide dynamic range, from –59dBm to 4dBm, depending on frequency.
Each AC signal’s power in decibel-scaled value is precisely converted to a DC voltage on a linear scale, independent of the crest factor of the input signal waveforms. The LTC5583 is suitable for precision power measurement and level control for a variety of RF standards, including LTE, EDGE, W-CDMA, CDMA2000, TD-SCDMA, and WiMAX.
查看全文
