Linear LTM4627 15A高效DC-DC电源解决方案
关键词:电源管理 DC/DC转换器 开关电源
时间:2010-09-26 11:01:07       作者:Linear       来源:LTM4627
Linear 公司的LTM4627是输出电流 15A的高效DC/DC转换器,输入电压从4.5V到20V,输出电压从0.6V到5V,并行电流输出电流可达60A,效率高达93%.主要用在通信服务器和网络设备,ATCA和存储卡,工业设备以及医疗系统.本文介绍了LTM4627主要特性, 简化方框图,以及多种应用电路.
The LTMR4627 is a complete 15A output high efficiency switch mode DC/DC power supply. Included in the package are the switching controller, power FETs, inductor and compensation components. Operating over an input voltage range from 4.5V to 20V, the LTM4627 supports an output voltage range of 0.6V to 5V, set by a single external resistor.Only a few input and output capacitors are needed. Current mode operation allows precision current sharing of up to four LTM4627 regulators to obtain 60A output. High switching frequency and a current mode architecture enable a very fast transient response to line and load changes without sacrificing stability. The device supports frequency synchronization, multiphase/current sharing operation, Burst Mode operation and output voltage tracking for supply rail sequencing.
The LTM4627 is offered in a thermally enhanced 15mmx 15mm x4.32mm LGA package. The LTM4627 is PB-free and RoHS compliant.
LTM4627主要特性:
Complete 15A Switch Mode Power Supply
查看全文
