Linear LTCR3589带I2C八输出电源稳压方案
关键词:电源管理 DC/DC转换器 I2C LDO
时间:2010-09-07 10:16:39       作者:Linear       来源:LTCR3589
Linear 公司的LTCR3589是带时序和I2C的八输出电源稳压器,是ARM和基于ARM处理器以及手提微处理器系统的完整的电源管理解决方案。LTCR3589包括用于核,存储器和SoC的三个同步降压DC/DC转换器,用于I/O的同步降压-升压稳压器,以及三个用于低噪音模拟电源的250mA LDO稳压器。本文介绍了LTCR3589主要特性,方框图以及典型应用电路。
LTCR3589:8-Output Regulator with Sequencing and I2C
The LTCR3589 is a complete power management solution for ARM and ARM-based processors and advanced portable microprocessor systems. The device contains three synchronous step-down DC/DC converters for core, memory and SoC rails, a synchronous buck-boost regulator for I/O at 3.3V to 5V, and three 250mA LDO regulators for low noise analog supplies. An I2C serial port is used to control regulator enables, output voltage levels, dynamic voltage scaling and slew rate, operating modes and status reporting.
查看全文
