ST FLI7515(25) 120 Hz 3DTV解决方案
关键词:消费类电子 iDTV 3DTV
时间:2010-09-02 10:33:03       作者:ST       来源:FLI7515
ST 公司的FLI7515和FLI7525是支持120 Hz FRC和3DTV的H.264 iDTV 系统级芯片(SoC).集成了用于高清视频译码(H.264/VC-1/MPEG2/)的450MHz ST231,用于多路音频译码的(MPEG-1/2, MP3,WMA等)的450MHz 双ST231,提供1700+ DMIPS性能运行在Linux和OS21的450MHz的双ST40 CPU,完全支持HDMI 1.4a 强制3DTV输入格式,主要应用在支持120 Hz 3DTV的高性能主流iDTV,以及支持DVB/ATSC/DTMB/ISDB的DTV.本文介绍了FLI7515和FLI7525主要特性,方框图,以及支持100/120 Hz FRC 和和3DTV的EU/US DTT + 有线iDTV应用框图.
FLI7515/25:Freeman Premier— H.264 iDTV SoC Integrated 120Hz FRC with 3DTV support
The Freeman Premier series of ICs are revolutionary new iDTV SoCs that integrate two highly successful, market-proven subsystems: STi710x digital/front-end processing and multi-format audio/video decoding from the STB market, and Faroudja video/back-end processing from the TV market. The Premier series are high-performance, state-of-the-art SoCs that can power DTT/cable/satellite/IPTV iDTV designs for worldwide deployment. From the software compatibility extending from the mature STi710x STAPI layer to the extensive video processing, tuning, and tools from Faroudja Labs, Freeman Premier are ideal solutions for addressing the next generation of iDTV design requirements.
查看全文
