Wolfson 公司的WM2002是采用Wolfson myZoneTM环境噪音消(ANC)除技术的立体声耳机驱动器,可采用单端或BTL输出配置,支持模拟播放或语音输入,模拟或数字麦克风。WM2002集成了功率管理,包括DC/DC转换器,电荷泵和LDO稳压器,采用单节AAA电池供电。环境噪音可降低25dB(典型值),降噪带宽(40Hz -4kHz) ,BTL驱动的THD+N可达-80dB。主要用在带ANC的手机,耳机以及蓝牙单声道/立体声手机。本文介绍了WM2002主要特性,方框图,典型应用框图以及推荐外接元件数值和DC1升压转换器和电荷泵外接元件数值。
Stereo Headphone Driver with Wolfson myZoneTM Ambient Noise Cancellation
The WM2002 is a low power, high quality stereo headphone driver, delivering Wolfson’s patented myZoneTM ambient noise cancellation in a single-ended or BTL (bridge-tied-load) output configuration. The WM2002 supports analogue playback or voice input, and analogue or digital microphone inputs for noisemonitoring microphones.
Designed for embedded applications or incorporated within a stand-alone headset or headphone, the Wolfson myZone™ ANC noise cancellation engine performs ambient noise cancellation during a voice call or during music playback.
The ambient noise input is supported via single-ended or differential analogue microphone interfaces; digital microphone input is also supported. Up to 10 noise input microphones can be supported at once.
分享到:
