Microchip PIC24F16KA102 XLP 16位MCU开发方案
关键词:工业控制 数据采集 传感器 MCU
时间:2010-08-23 10:20:10       作者:Microchip       来源:PIC24F16KA102
Microchip 公司的PIC24F16KA102是极低16位MCU,采用改进型哈佛架构,32MHz时高达16MIPS,带4x PLL选择和多个除法选择的8MHz振荡器,17位x17位单周期硬件乘法器,32位x16位硬件除法器,16位x16位工作寄存器阵列,C编译器,运行模式的功耗低到8uA,深度睡眠模式的功耗为20nA,工作电压1.8V到 3.6V,住要用途包括RF传感器,数据采集器,温度传感器,电子门锁,测量传感器,遥控,安全传感器,智能卡和能量收获等。本文介绍了PIC24F16KA102主要特性,方框图以及 XLP 16位MCU开发套件主要特性和XLP 16位开发板详细电路图。
The PIC24F16KA102 family introduces a new line of extreme low-power Microchip devices: a 16-bit microcontroller family with a broad peripheral feature set and enhanced computational performance. It also offers a new migration option for those high-performance applications, which may be outgrowing their 8-bit platforms, but do not require the numerical processing power of a digital signal processor.
PIC24F16KA102主要特性:
Power Management Modes:
• Run – CPU, Flash, SRAM and Peripherals On
• Doze – CPU Clock Runs Slower than Peripherals
• Idle – CPU Off, Flash, SRAM and Peripherals On
• Sleep – CPU, Flash and Peripherals Off and SRAM On
• Deep Sleep – CPU, Flash, SRAM and Most Peripherals Off
- Run mode currents down to 8uA typical
- Idle mode currents down to 2 uA typical
查看全文
