TI TPA2015高效D类音频功率放大解决方案
关键词:消费类电子 D类放大器 手机 PDA GPS
时间:2010-07-30 10:09:39       作者:TI       来源:TPA2015
TI 公司的TPA2015是高效D类音频功率放大器,采用电池跟踪SpeakerGuard AGC技术,并集成了自适应的升压转换器,能增加低输出功率的效率。3.6V电源时TPA2015能向8欧姆扬声器提供2W功率,THD为6%,效率85%。工作电压2.5V-5.2V,带自动恢复的热和短路保护,有三种增益设定:6 dB, 15.5 dB和20 dB,主要用在手机,PDA,GPS,手提电子学和扬声器。本文介绍了TPA2015主要特性,功能方框图,性能测试框图以及差分和单端输入典型应用方框图,放大器评估板TPA2015D1主要指标,电路图和材料清单。
The TPA2015D1 is a high efficiency Class-D audio power amplifier with battery-tracking SpeakerGuard AGC technology and an integrated adaptive boost converter that enhances efficiency at low output power. It drives up to 2 W into an 8  speaker (6% THD). With 85% typical efficiency, the TPA2015D1 helps extend battery life when playing audio.
The built-in boost converter generates a 5.5 V supply voltage for the Class-D amplifier. This provides a louder audio output than a stand-alone amplifier directly connected to the battery. The SpeakerGuardTM AGC adjusts the Class-D gain to limit battery current and prevent heavy clipping.
The TPA2015D1 has an integrated low-pass filter to improve the RF rejection and reduce DAC out-of-band noise, increasing the signal to noise ratio (SNR).
TPA2015主要特性:
Built-In SpeakerGuard™ Automatic Gain Control (AGC)
查看全文
