Linear LT3596 60V降压LED驱动方案
关键词:电源管理 LED驱动器 DC/DC转换器
时间:2010-07-19 15:05:17       作者:Linear        来源:LT3596 60V
The LTR3596 is a 60V step-down LED Driver. It achieves 10,000:1 digital PWM dimming at 100Hz with fast NPN current sources driving up to 10 LEDs in each channel. 100:1 LED dimming can also be done with analog control of the CTRL1-3 pin.
The step-down switching frequency is programmable between 200kHz and 1MHz and is synchronizable to an external clock. The LT3596 also provides maximum LED brightness while adhering to manufacturers’ specifications for thermal derating. The derate temperature is programmed by placing a negative temperature coefficient (NTC) resistor on the master control pin.
The LT3596 adaptively controls VOUT in order to achieve optimal efficiency. Other features include: 1.5% LED current matching between channels, open LED reporting, shorted LED pin protection and reporting, programmable LED current and programmable temperature protection.
LTR3596主要特性:
n 300mA Buck Regulator, Drives Up to 10 LEDs per Channel with Fast NPN Current Sources
n Fast Current Sources for <1μs Pulse Widths (10,000:1 True Color PWM™ Dimming at 100Hz)
n LEDs Disconnected in Shutdown
n Adaptive VOUT for Increased Efficiency..
查看全文
