关键词:电源管理 LED驱动器 AC/DC转换器 TRIAC
时间:2010-06-22 10:31:09 作者:PowerInt 来源:中电网
PowerInt 公司的LinkSwitch-PH系列集成了725V功率MOSFET,连续模式PWM控制器,用于自偏置的高压开关电流源,频率抖动,逐个周期的电流限制以及延迟热关断电路,大大地简化PF大于0.9, TRIAC调光的LED驱动器的设计,主要用在离线LED驱动器.本文介绍了LinkSwitch-PH系列主要特性,功能方框图, TRIAC调光14W 和7W LED驱动器电路图,以及TRIAC调光14W LED驱动器参考设计主要指标,电路图和材料清单(BOM).
The LinkSwitch-PH dramatically simplifies implementation of LED drivers requiring PF >0.9, TRIAC dimmer capability and high efficiency. The single-stage PF and constant current controller eliminates passive circuitry required for power factor correction and electrolytic bulk capacitor. The advanced primary-side control techniques used by the LinkSwitch-PH device provide accurate constant current control while eliminating the need for an optocoupler and secondary-side current control circuitry.
LinkSwitch-PH incorporates a 725 V power MOSFET, a continuous-mode PWM controller, a high voltage switched current source for self biasing, frequency jittering, cycle-by-cycle current limit and hysteretic thermal shutdown circuitry, all in a monolithic IC.
LinkSwitch-PH系列主要特性:
Dramatically Simplifies Off-line LED Drivers
• Flicker-free phase-controlled TRIAC dimming
分享到:
