ADI ADP8863带电荷泵驱动的LED驱动方案
关键词:电源管理 LED驱动器 电荷泵
时间:2010-06-21 11:30:46       作者:ADI       来源:中电网
ADI公司的ADP8863是具有先进的自治的LED光特性的功1强大的电荷泵驱动器,能独立地驱动多达7个LED,每个电流高达30mA,第7个LED的驱动电流可高达60mA.电荷泵的自动增益选择有1x,1.5x 和2x,工作电压从2.5 V 到5.5 V,可驱动最大电流240mA,主要用在LED指示器,装饰指示照明,键盘照明,RGB LED色彩发生和蔼混合以及小型显示器通用照明.本文介绍ADP8863主要特性,详细方框图以及多种应用电路.
The ADP8863 combines a powerful charge pump driver with advanced autonomous LED lighting features. It allows as many as seven LEDs to be independently driven up to 30 mA (maximum). The seventh LED can also be driven to 60 mA (maximum). All LEDs are programmable for maximum current and fade in/fade out times via the I2C interface.
Additionally, automated blinking routines can be independently programmed and enabled for all seven LED channels. These LEDs can also be combined into groups to reduce the processor instructions.
查看全文
