ST 公司的SPV1020是内置了MPPT算法的PWM模式DC/DC升压转换器,能最大化太阳能电池板所产生的能量,不受温度和太阳辐射的影响。MPPT算法精度在0.2%,工作电压0-36V,具有过压,过流和超温保护,内置了软起动,效率高达98%。本文介绍了SPV1020主要特性,方框图和应用电路。
Interleaved DC-DC boost converter with built-in MPPT algorithm SPV1020 is a monolithic DC-DC boost converter designed to maximize the power generated by photovoltaic panels independently of temperature and amount of solar radiation.
The optimization of the power conversion is obtained with an embedded logic which performs the MPPT (max power point tracking) algorithm on the PV cells connected to the converter.
One or more converters can be housed in the connection box of PV panels, replacing the bypass diodes, and thanks to the fact that the maximum power point is locally computed, the efficiency at system level will be higher than the one of conventional topologies, where the MPP is computed in the main centralized inverter.
分享到:
