Linear LT3958输出可正可负DC-DC电源转换方案
关键词:电源管理 DC/DC转换器 SEPIC
时间:2010-06-12 11:22:49       作者:Linear       来源:中电网
Linear 公司的LT3958是宽输入电压(5V-80),电流模式,输出可正可负DC-DC电源转换器,可配置成升压,反激,SEPIC或反相转换器。LT3958集成了84V/3.3A N沟功率MOSFET和7.2V LDO稳压器,可编开关频率100kHz到1MHz,能和外部时钟同步,主要用在汽车,通信和工业领域。本文介绍了LT3958主要特性,方框图,以及多种应用电路图。
The LT3958 is a wide input range, current mode, DC/DC converter which is capable of generating either positive or negative output voltages. It can be configured as either a boost, flyback, SEPIC or inverting converter. It features an internal low side N-channel power MOSFET rated for 84V at 3.3A and driven from an internal regulated 7.2V supply. The fixed frequency, current-mode architecture results in stable operation over a wide range of supply and output voltages.
The operating frequency of LT3958 can be set with an external resistor over a 100kHz to 1MHz range, and can be synchronized to an external clock using the SYNC pin.
A minimum operating supply voltage of 5V, and a low shutdown quiescent current of less than 1μA, make the LT3958 ideally suited for battery-powered systems. The LT3958 features soft-start and frequency foldback functions to limit inductor current during start-up.
LT3958主要特性:
Wide Input Voltage Range: 5V to 80V
查看全文
