NXP BLF888 500W RF广播发射方案
关键词:通信技术 无线通信 RF UHF
时间:2010-05-20 10:44:22       作者:NXP       来源:中电网
NXP 公司的BLF888是500W LDMOS RF功率晶体管,用于广播发射和工业应用。在UHF频带470 MHz 到860 MHz可提供平均功率110W,峰值包络功率500W,功率增益19dB,漏极效率46%,VDS 电压50 V,漏极静态电流1.3A。本文主要介绍了BLF888主要特性和优势,AB类共源宽带放大器电路和元件列表以及PCB布局图和元件布局图。
A 500 W LDMOS RF power transistor for broadcast transmitter applications and industrial applications. The transistor is optimized for digital applications and can deliver 110 W average DVB-T broadband over the full UHF band from 470 MHz to 860 MHz. The excellent ruggedness of this device makes it ideal for digital transmitter applications.
BLF888主要特性和优势:
2-Tone performance at 860 MHz, a drain-source voltage VDS of 50 V and a quiescent drain current IDq = 1.3 A:
Peak envelope power load power = 500 W
Power gain = 19 dB
Drain efficiency = 46 %
Third order intermodulation distortion = 32 dBc
DVB performance at 858 MHz, a drain-source voltage VDS of 50 V and a quiescent drain current IDq = 1.3 A:
Average output power = 110 W
Power gain = 19 dB
Drain efficiency = 31 %
Shoulder distance = 31 dBc (4.3 MHz from center frequency)..
查看全文
