Atmel AT32UC3A EVK1105 32位MCU开发方案
关键词:消费类电子 组合音响 MP3播放器
时间:2010-05-06 14:39:19       作者:Atmel       来源:中电网
Atmel 公司的AT32UC3A 是完整的系统级芯片微控制器,采用VR32 UC RISC,工作频率高达66MHz,设计用于对成本敏感的嵌入式应用,特别是低功耗,高代码效率和高性能. AT32UC3A还集成了闪存和SRAM存储器,外设直接存储器访问控制器(PDCA),以及PowerManager电源管理.此外还有多种通信接口如UART,SPI,TWI,同步串行控制器,USB和以太网MAC等.本文介绍了AT32UC3A主要特性, 方框图以及32位AVR EVK1105评估板特性,详细电路图和材料清单(BOM).
AVR®32 32-Bit Microcontroller
The AT32UC3A is a complete System-On-Chip microcontroller based on the AVR32 UC RISC processor running at frequencies up to 66 MHz. AVR32 UC is a high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption, high code density and high performance.
The processor implements a Memory Protection Unit (MPU) and a fast and flexible interrupt controller for supporting modern operating systems and real-time operating systems. Higher computation capabilities are achievable using a rich set of DSP instructions.
The AT32UC3A incorporates on-chip Flash and SRAM memories for secure and fast access. For applications requiring additional memory, an external memory interface is provided on AT32UC3A0 derivatives.
查看全文
