iWatt iW3620 40W AC-DC LED驱动方案
关键词:电源管理 LED驱动器 AC/DC转换器
时间:2010-05-04 11:23:42       作者:iWatt       来源:中电网
iWatt 公司的iW3620是高性能AC/DC离线LED驱动器,器件在高负载条件下工作在准谐振模式,以得到高的效率和各种内置的保护特性,降低EMI,工作频率高达130kHz,通用输入电压85 Vac到 264 Vac,可驱动40W 的LED照明。本文介绍了iW3620主要特性以及典型应用电路。
iW3620:Digital PWM Constant Current Controller for AC/DC LED Driver
The iW3620 is a high performance AC/DC offline LED driver which uses digital control technology to build peak current mode PWM flyback power supplies. The device operates in quasi-resonant mode at heavy load to provide high efficiency along with a number of key built-in protection features while minimizing the external component count, simplifying EMI design and lowering the total bill of material cost. The iW3620 removes the need for secondary feedback circuitry while achieving excellent line and load regulation. It also eliminates the need for loop compensation components while maintaining stability over all operating conditions. Pulse-by-pulse waveform analysis allows for a loop response that is much faster than traditional solutions, resulting in improved dynamic load response. The built-in current limit function enables optimized transformer design in universal off-line applications over a wide input voltage range.
iW3620主要特性:
查看全文
