IR IRS2573D 70W HID灯参考设计方案
关键词:电源管理 氙气灯(HID) 镇流器
时间:2010-04-23 14:44:11       作者:IR       来源:中电网
IR 公司的IRS2573D是全集成全保护的600V氙气灯(HID)控制器,能驱动所有类型的氙气灯(HID)灯. IRS2573D包括点火时间控制,恒定灯功率控制,可编程全桥运行频率,可编程过压和欠压保护以及可编程过流保护. 此外,器件还集成了600V高边和低边全桥驱动器,以及600V高边降压驱动器等.本文介绍IRS2573D 主要特性,功能方框图,以及典型应用电路和70W HID灯参考设计电路图,主要指标,材料清单和PCB布局图.
The IRS2573D is a fully-integrated, fully-protected 600V HID control IC designed to drive all types of HID lamps.
Internal circuitry provides control for ignition, warm-up, running and fault operating modes. The IRS2573D features include ignition timing control, constant lamp power control, programmable full-bridge running frequency, programmable over and under-voltage protection and programmable over-current protection. Advanced protection features such as failure of a lamp to ignite, open load, short-circuit and a programmable fault counter have also been included in the design.
IRS2573D 主要特性:
Buck, full-bridge and lamp control in one IC
Continuous/critical-conduction mode buck control
600V high and low-side full-bridge driver
600V high-side buck Driver
Low-side ignition FET gate driver
Integrated bootstrap FETs for full-bridge high-side drivers
Constant lamp power control
查看全文
