Micrel公司的MIC3263是六路白光LED(WLED)驱动器,采用高效的PWM升压开关技术,最适合用于恒流WLED背光驱动.每路电流的匹配在±3%,电流在15mA到30mA可编程.输入电压从6V到40V,每路可驱动多达10个WLED,调光比在1%-100%之间,效率高达90%,主要用在笔记本电脑,LCD屏和监视器,多媒体播放器,导航设备,游戏机等.本文介绍MIC3263主要特性,功能方框图,典型应用电路以及MIC3263评估板电路图和材料清单(BOM).
MIC3263; Six-Channel WLED Driver for Backlighting Applications with Flicker-Free Dimming
The MIC3263 is a high-efficiency Pulse Width Modulation (PWM) boost switching regulator that is optimized for constant-current WLED driver backlighting applications. The MIC3263 drives six channels of up to ten WLEDs per channel. Each channel is matched in current to within ±3% for constant brightness across the screen and can be programmed from 15mA to 30mA.
The MIC3263 provides a very flexible dimming control scheme with better accuracy and noise immunity. The dimming frequency can be set to any value between 100Hz and 20kHz by an external resistor. The dimming ratio is determined by the duty cycle of a dimming ratio control input signal and can be set to one of 16 levels with a minimum ratio of 1%.The LED dimming current is set by an external resistor to allow programming of LED current between 15mA and 30mA.
分享到:
