Intersil 公司的ISL8204M和ISL8206M是高效容易使用的大功率DC-DC转换模块, ISL8204M的电流为4A,峰值电流达6.6A, ISL8206M的电流为6A,峰值电流达8.8A,输入电压从1VDC到20VDC,单电阻设定输出电压从0.6V到6V,效率高达95%,具有过流保护和软起动功能,主要用在服务器,通信,工业设备,POL稳压和通用降压DC/DC转换器.本文介绍ISL8204M主要特性和功能方框图, 性能测试电路图, 应用电路图以及评估板电路图和评估板材料清单(BOM).
The ISL8204M, ISL8206M is a family of pin-compatible power modules to the ISL8201M. These are simple and easy to use, high power DCDC modules and are ideal for a wide variety of applications. The ISL820xM family of high current DCDC step-down modules virtually eliminate design and manufacturing risks while dramatically improving time to market.
The simplicity is in the familys "Off The Shelf" unassisted implementation. All you need is the ISL820xM for the current requirement of your design, bulk input and output capacitors and one resistor, to program the output voltage, and you have a complete high current power design ready for your market.
分享到:
