NS 公司的LMZ1420x 和LMZ1200x SIMPLE SWITCHER 是容易使用的3A DC/DC解决方案,有极好的电源转换效率,输出电压精度,线路和负载调整, LMZ14203/2/1输入电压在6-42V之间, LMZ12003/2/1输入电压在4.5V-20V之间,输出电压可低至 0.8V,高至6V.效率高达90%.主要用在POL,空间受限和高热需求的应用,负输出电压应用.本文介绍LMZ1420x 和LMZ1200x主要特性, 应用方框图和LMZ1420x / LMZ1200x 评估板与材料清单(BOM).
The LMZ1420x and LMZ1200x SIMPLE SWITCHER? Power modules are easy-to-use DC-DC solution capable of driving up to a 3A load with exceptional power conversion efficiency, output voltage accuracy, line and load regulation. They are available in an innovative package that enhances thermal performance and allows for hand or machine soldering.
分享到:
