NS LMZ10504 4A SIMPLE SWITCHER DC-DC解决方案
关键词:电源管理 DC/DC转换器
时间:2010-01-28 00:00:00       来源:NS
NS 公司的LMZ10504 SIMPLE SWITCHER 是容易使用的4A DC/DC解决方案,有极好的电源转换效率,输出电压精度,线路和负载调整, LMZ10504输入电压在2.95-5.5V之间,输出电压可低至 0.8V,效率高达96%.主要用在POL,空间受限和高热需求的应用,对噪音要求严格的应用如收发器和医疗设备.本文介绍LMZ10504主要特性, 多种应用方框图和相应的材料清单(BOM).
LMZ10504: 4A SIMPLE SWITCHER? Power Module with 5.5V Maximum Input Voltage The LMZ10504 SIMPLE SWITCHER? power module is a complete, easy-to-use DC-DC solution capable of driving up to a 4A load with exceptional power conversion efficiency,output voltage accuracy, line and load regulation. The LMZ10504 is available in an innovative package that enhances thermal performance and allows for hand or machine soldering.
The LMZ10504 can accept an input voltage rail between 2.95V and 5.5V and deliver an adjustable and highly accurate output voltage as low as 0.8V. One megahertz fixed frequency PWM switching provides a predictable EMI characteristic.
Two external compensation components can be adjusted to set the fastest response time, while allowing the option to use ceramic and/or electrolytic output capacitors. Externally programmable soft-start capacitor facilitates controlled startup.
查看全文
