ST 公司的TS4982 是集成了参考地耳机驱动器的2W立体声音频功率放大器.单电源5V工作,每路能向4欧姆负载输出2W,此时的THD+N为1%, 耳机驱动器能向16欧姆负载输出125mW.主要应用在笔记本电脑和手提音频设备.本文介绍TS4982主要特性, 方框图, 典型应用电路图和外接元件表,以及演示板STEVAL-CCA019V1主要特性和电路图.
TS4982: 2 W stereo audio power amplifier with ground-referenced headphone driver The TS4982 features a stereo loudspeaker driver and a ground-referenced stereo headphone driver. An independent standby mode pin allows the TS4982 to simultaneously drive both output drivers. Operating on a single 5 V supply, the TS4982 delivers 2 W (typ.) output power into a 4 ohm load at 1% THD+N.
The TS4982 features a PC beep input, three levels of 3D stereo enhancement and 4-step gain control using two digital input pins. Minimum external components make the TS4982 wellsuited for notebook and other hand-held sound equipment. It also has an internal thermal shutdown (150℃) and output short circuit protection mechanism.
TS4982主要特性:
■ 2 W output power into 4 ohm load per channel
■ 125 mW into 16 0hm load ground-referenced stereo headphone driver
■ Four-step gain settings on speaker path
■ 3 levels of 3D effect on speaker path
■ PC-beep input system detection
分享到:
