TI 公司的TPS3860x0系列是四路电压监视器,具有可编程延迟(1.4ms到10s)和看门狗定时器, 监视电压大于0.4V,阈值精度0.25%,非常低的静态电流(12uA),主要用在模拟加序,所有的DSP和MCU应用, 所有的FPGA/ASIC应用.本文介绍了TPS3860x0系列主要特性,方框图, 典型应用电路,以及TPS386000 和TPS386040的评估模块主要特性,电路图和所用材料清单.
Quad Supply Voltage Supervisors with Programmable Delay and Watchdog Timer
The TPS3860x0 family of voltage supervisors can monitor four power rails that are greater than 0.4V with a 0.25% (typical) threshold accuracy. Each of the four supervisory circuits (SVS-n) assert a RESETn or RESETn output signal when the SENSEm input voltage drops below the programmed threshold. With external resistors, the threshold of each SVS-n can be programmed (where n = 1, 2, 3, 4 and m = 1, 2, 3, 4L, 4H).
Each SVS-n has a programmable delay before releasing RESETn or RESETn, and the delay time can be set from 1.4ms to 10s through the CTn pin connection. Only SVS-1 has an active-low manual reset (MR) input; a logic-low input to MR asserts RESET1 or RESET1.
SVS-4 monitors the threshold window using two comparators. The extra comparator can be configured as a fifth SVS to monitor negative voltage with voltage reference output VREF.
分享到:
