Fairchild 公司的FIN210是低功耗10位并串/并串转换器,支持照相机和小型显示器,时钟速率高达48MHz.接口包括MCU,RGB和YUV,待机电流小于10uA,内核工作电压2.8V-3.6V,I/O电压1.65V-3.6V,I/O到低的ESD保护高达15KV,主要应用于移动手机,打印机和安全照相机.本文介绍了FIN210的主要特性,以及各种应用案例,包括在手机, 8位RGB, 8位YUV 130万象素CMOS传感器以及8位仅写入MCU接口的应用框图.
FIN210AC: 10-Bit Serializer / Deserializer Supporting Cameras and Small Displays up to 48MHz
The FIN210AC μSerDes™ is a low-power serializer / deserializer optimized for use in cell phone displays and camera paths. The device reduces a 10-bit data path to four wires. For camera applications, an additional master clock can be passed in the opposite direction of data flow. The device utilizes Fairchild’s proprietary ultra-low power, low- EMI technology.
FIN210主要特性:
FIN210应用:
Slider, Folder, & Clamshell Mobile Handsets
Printers
Security Cameras
图1.FIN210在手机中的应用框图
图2.FIN210在8位RGB中的应用框图
Serializer Configuration: 10MHz to 30MHz Frequency Range (S1=S0=1) Normal Mode (PLL1=0; PLL0=1)
Deserializer Configuration: ~4 – 5ns output edge rates (S1=S0=1) ~50% CKP PW,(PWS1=PWS0=0)
图3.FIN210在8位YUV 130万象素CMOS传感器中的应用框图
分享到:
