ST TS4657高性能立体声DAC方案
关键词:消费类电子 DVD HDTV STB
时间:2009-10-23 10:43:00       来源:ST
ST公司的TS4657是集成高性能音频线路驱动器的立体声DAC,能从3.0V-5.5V单电源中产生2.2Vrms的输出.取样频率32-48kHz,16-24位音频数据格式,SNR为95dB,主要应用在数字机顶盒,DVD播放器,DTV,笔记本电脑,手提音频设备和声卡.本文介绍了TS4657主要特性,方框图,典型应用电路和测试电路.
The TS4657 is a stereo DAC that integrates a high-performance audio line driver capable of generating a 2.2 Vrms output level from a single 3.0 to 5.5 V supply. One single supply is sufficient for the digital and analog parts of the circuit, thus eliminating the need for external regulators.
The TS4657 is a low-power consumption device. It features only 22 mW power dissipation at a 3.0 V power supply in full operation. A 16-bit multi-bit sigma delta DAC is used,operating at 256xFs with oversampling digital interpolation filters. The digital audio data can be 16-to 24-bit long and sample rates from 32 to 48 kHz are supported.
The output stage signal is ground-referenced by using an internal self-generated negative power supply, and as such external bulky output coupling capacitors are not necessary.
The TS4657 is packaged in a small 4 x 4 mm QFN20 package, ideal for portable applications.
TS4657主要特性:
■ Single 3.0 to 5.5 V supply for DAC and line driver
查看全文
