Microchip 公司的PIC24F 系列是带UTG的16位闪存MCU,片内有2.5V电压稳压器, CPU采用改进型哈佛架构,32MHz高达16MIPS,内部有8MHz振荡器,17位x17为单周期硬件乘法器,32位x16位硬件除法器, 工作电压2.0V 到3.6V,适合于各种触摸应用. mTouch容性评估板为开发各种触摸屏提供了简单平台,包括有两个主板,连接到4个传感器板.本文介绍了PIC24F 系列的主要特性, mTouch评估板的CTMU板应用侧方框图,电路图和CSM板应用侧方框图与电路图.
PIC24F 系列:16-Bit Flash Microcontrollers with USB On-The-Go (OTG)
This document contains device-specific information for the following devices:
. PIC24FJ64GB106 . PIC24FJ192GB108
. PIC24FJ128GB106 . PIC24FJ256GB108
. PIC24FJ192GB106 . PIC24FJ64GB110
. PIC24FJ256GB106 . PIC24FJ128GB110
. PIC24FJ64GB108 . PIC24FJ192GB110
. PIC24FJ128GB108 . PIC24FJ256GB110
Power Management:
. On-Chip 2.5V Voltage Regulator
. Switch between Clock Sources in Real Time
. Idle, Sleep and Doze modes with Fast Wake-up and Two-Speed Start-up
. Run mode: 1 mA/MIPS, 2.0V Typical
. Sleep mode Current Down to 100 nA Typical
. Standby Current with 32 kHz Oscillator: 2.5uA, 2.0V typical
Universal Serial Bus Features:
. USB v2.0 On-The-Go (OTG) Compliant
. Dual Role Capable . can act as either Host or Peripheral
分享到:
