MAXIM MAX16834 大功率LED驱动方案
关键词:电源管理 HBLED照明 LCD SEPIC
时间:2009-09-14 14:00:00       来源:MAXIM
MAXIM公司的MAX16834是一款电流模式高亮度LED(HB LED)驱动器,具有升压、降压升压、SEPIC、高侧降压拓扑结构。除了通过开关控制器控制驱动n沟道功率MOSFET开关,MAX16834还驱动一个n沟道PWM调光开关实现LED PWM调光。MAX16834工作电压范围为4.75V~28V,包括一个3A沉/源栅极驱动器。MAX16834具有可编程的斜率补偿的恒定频率峰值电流模式控制,以控制PWM控制器的占空比。主要用于单串LED LCD背景光,汽车前后端照明,投影系统RGB LED照明源,建筑和装饰照明(MR16, M111),场所和环境照明,以及DC-DC升压/降压转换器。本文介绍了MAX16834主要特性、方框图和各种应用电路包括升压LED驱动器, 升-降压LED驱动器,有汽车负载保护的升压LED驱动器以及高侧降压型LED驱动器, 升压型DC-DC转换器和降压-升压型DC-DC转换器。
The MAX16834 is a current-mode high-brightness LED (HB LED) driver for boost, buck-boost, SEPIC, and highside buck topologies. In addition to driving an n-channel power MOSFET switch controlled by the switching controller, it also drives an n-channel PWM dimming switch to achieve LED PWM dimming. The MAX16834 integrates all the building blocks necessary to implement a fixed-frequency
HB LED driver with wide-range dimming control.The MAX16834 features constant-frequency peak current-mode control with programmable slope compensation to control the duty cycle of the PWM controller.
查看全文
