PowerOne ZY2120总线编程POL数字稳压方案
关键词:电源管理 DC/DC转换器 POL负载
时间:2009-08-04 14:09:00       来源:PowerOne, , ,
PowerOne 公司的ZY2120是智能的全编程降压点负载(POL)DC/DC转换模块,集成了数字电源转换器和功率管理单元. ZY2120输入电压为8V到14V,连续输出电流20A,可编程输出电压0.5V-5.5V,并有富余量和数字电流共享. ZY2120具有过压,过流,欠压和超温保护,功率良好信号跟踪输出电压,具有多领域应用,包括具有中间总线架构(IBA)的低压高密度系统,用于高性能DSP,FPGA,ASIC和微处理器的点负载稳压器,工业计算,服务器和存储以及宽带,网络,光纤和无线通信系统等.本文介绍了ZY2120主要特性,优势和三独立输出应用电路图以及多输出应用框图和模块和外接滤波器连接图.
The ZY2120 is an intelligent, fully programmable step-down point-of-load DC-DC module integrating digital power conversion and power management. The ZY2120 eliminates the need for external components for sequencing, tracking, protection, monitoring, and reporting. Performance parameters of the ZY2120 are programmable by pin strapping and an external resistor, and can be changed by the user at any time during product development and service without a need for a communication bus.
ZY2120主要特性:
RoHS lead free and lead-solder-exempt products are available
Wide input voltage range: 8V–14V
High continuous output current: 20A
Wide programmable output voltage range: 0.5V–5.5V
Active digital current share
Output voltage margining
查看全文
