NS LM3421-3高压LED驱动方案
关键词:NSLM3421/LM3423
时间:2009-7-15 14:37:00      来源:NS, , ,
NS公司的LM3421/LM3423是多用途高压LED驱动,可以配置成降压,升压,降压-升压(反激)或SEPIC拓扑,输入电压从4.5V到高达75V,可调开关频率高达2MHz,具有快速(50kHz) PWM调光,关断电流小于1uA,可用在LED驱动器和多种恒流模式稳压器以及热电冷却驱动器.本文介绍了LM3421/LM3423的住
NS公司的LM3421/LM3423是多用途高压LED驱动,可以配置成降压,升压,降压-升压(反激)或SEPIC拓扑,输入电压从4.5V到高达75V,可调开关频率高达2MHz,具有快速(50kHz) PWM调光,关断电流小于1uA,可用在LED驱动器和多种恒流模式稳压器以及热电冷却驱动器.本文介绍了LM3421/LM3423的住要特性,方框图以及多种应用电路图,升压评估板主要特性和电路图和材料清单(BOM).
LM3421/ LM3423:N-Channel Controllers for Constant Current LED Drivers
The LM3421/LM3423 devices are versatile high voltage LED driver controllers. With the capability to be configured in a Buck, Boost, Buck-Boost (Flyback), or SEPIC topology, and an input operating voltage rating of 75V, these controllers are ideal for illuminating LEDs in a very diverse, large family of applications.
Adjustable high-side current sense with a typical sense voltage of 100mV allows for tight regulation of the LED current with the highest efficiency possible. Output LED current regulation is based on peak current-mode control with predictive Off-Time Control. This method of control eases the design of loop compensation while providing inherent input voltage feed-forward compensation.
The LM3421/LM3423 include a high-voltage startup regulator that operates over a wide input range of 4.5V to 75V. The internal PWM controller is designed for adjustable switching frequencies of up to 2.0MHz, thus enabling compact solutions.
Additional features include: “zero” current shutdown, precision reference, logic compatible DIM input suitable for fast PWM dimming, cycle-by-cycle current limit, and thermal
shutdown.
The LM3423 also includes an LED output status flag, a fault flag, a programmable fault timer, and a logic input to select the polarity of the dimming output driver.
LM3421-3主要特性:
■VIN range from 4.5V to 75V
■2% Internal reference voltage (1.235V)
■Current sense voltage adjustable from 20mV
■High-side current sensing
■2Ω MOSFET gate driver
■Dimming MOSFET gate driver
■Input under-voltage protection
■Over-v...
  • 时 间:2026年5月19日
