[原创]TI LP87745-Q1 AWR和IWR雷达传感器降压转换器解决方案
关键词:电源管理 DC/DC转换器 雷达传感器 TI LP87745-Q1
时间:2022-08-15 13:56:40       来源:中电网
TI公司的LP8774x-Q1是满足各种汽车和工业雷达应用的AWR和IWR MMIC功率管理要求的器件.器件具有三个降压DC/DC转换器,一个5V升压转换器和1.8V/3.3V LDO. LDO由升压转换器供电,打算给xWR IO供电.器件由SPI串行接口和使能信号控制.降压DC/DC转换器支持可编开关频率4.4MHz,8.8MHz或17.6MHz.高开关频率和宽频率范围的低噪音使得无LDO功率解决方案,具有极少的或没有无源滤波器.器件满足AEC-Q100 规范:环境工作温度–40°C 到 +125°C,增加ISO 26262安全系统到ASIL-C/SIL-2,输入电源过压和欠压监视,稳压器输出过压和欠压监视,对外接电源轨进行过压和欠压监视.主要用在短距离和中距离雷达,超短距离雷达和长距离雷达.本文介绍了LP8774x-Q1主要特性, 简化电路图以及评估模块LP877451Q1EVM主要特性,电路图,材料清单和PCB设计图.
The LP8774x-Q1 device is designed to meet the power management requirements of the AWR and IWR MMICs in various automotive and industrial radar applications. The device has three step-down DC/DC converters, a 5 V boost converter and a 1.8 V/3.3V LDO. The LDO is powered from the boost and intended for xWR IO supply. The device is controlled
by an SPI serial interface and by enable signals.
The step-down DC/DC converters support programmable switching frequency of 4.4 MHz, 8.8 MHz, or 17.6 MHz. High switching frequency and low noise across wide frequency range enable LDO-free power solution with minimal or no passive filtering.
查看全文
