Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
  • Ê×Ò³ >  ½â¾ö·½°¸ >  [Ô­´´]ADI LTM4673Êý×ÖµçԴϵͳ¹ÜÀí¹¦ÄÜËÄ·Êä³ö¦ÌModuleÎÈѹÆ÷½â¾ö·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí ¦ÌModuleÎÈѹÆ÷ Êý×ÖµçԴϵͳ ADI LTM4673
ʱ¼ä£º2022-08-03 13:36:36       À´Ô´£ºÖеçÍø
ADI¹«Ë¾µÄLTM4673ÊǼ¯³É4ͨµÀµçԴϵͳ¹ÜÀíÆ÷µÄËÄͨµÀÊä³ö˫ͨµÀ12AºÍ˫ͨµÀ5AµÄ¿ª¹ØÄ£Ê½DC/DC½µÑ¹¦ÌModule(µçÔ´Ä£¿é)ÎÈѹÆ÷, ÓÃÓÚÅÅÐò,µ÷Õû(ËÅ·þ),Ô£Á¿µ÷½Ú,¼à¿Ø,¹ÜÀí¹ÊÕÏ,Ìṩң²â²¢´´½¨¹ÊÕÏÈÕÖ¾.LTM4673ÔÚ4.5VÖÁ15VµÄÊäÈëµçѹ·¶Î§ÄÚ¹¤×÷,12AͨµÀµÄÊä³öµçѹ·¶Î§Îª0.6VÖÁ3.3V,5AͨµÀµÄÊä³öµçѹ·¶Î§Îª0.6VÖÁ5.5V.½öÐèÒª´óÈÝÁ¿ÊäÈëºÍÊä³öµçÈÝ.LTM4673¾ßÓÐË«Ïßʽ´®ÐнӿÚ,¿É¶ÔÊä³ö½øÐо«È·µØÔ£Á¿µ÷½Ú,΢µ÷ºÍ¿É±à³ÌÉϵçºÍ¹Ø¶ÏʱÐò¿ØÖÆ.ÄÚ²¿16λADC¿É¼à¿ØÊäÈëºÍËùÓÐËĸöÊä³öµçѹ,µçÁ÷ºÍζÈ.¿É¶ÔËĸöÊä³öͨµÀµÄ¹ýÁ÷ºÍÇ·µçÁ÷,µçѹºÍζÈãÐÖµÏÞÖÆÒÔ¼°ÊäÈë¹ýѹºÍǷѹ½øÐйÊÕϱà³Ì.LTM4673²ÉÓÃ16mm ¡Á 16mm ¡Á 4.72mm BGA·â×°,Ìṩ·ûºÏRoHS±ê×¼µÄ¶Ë×Ó±íÃæ.Ö÷ÒªÓÃÔÚµçÐÅ,ÍøÂçºÍ¹¤ÒµÉ豸,¶à¹ì¸ºÔصãµ÷ÕûÒÔ¼°FPGA,DSPºÍASICÓ¦ÓÃ.±¾ÎĽéÉÜÁËLTM4673Ö÷ÒªÌØÐÔ,¿òͼ,¶àÖÖÓ¦Óõç·, ÑÝʾ°åDC2810AÖ÷ÒªÌØÐԺͲâÁ¿É豸½¨Á¢Í¼,µç·ͼºÍ²ÄÁÏÇåµ¥.
The LTMR4673 is a quad output, dual 12A and dual 5A, switching mode DC/DC step-down ¦ÌModule (powermodule) regulator integrated with 4-channel Power System Manager used to sequence, trim (servo), margin, supervise, manage faults, provide telemetry, and create fault logs. Operating over an input voltage range of 4.5V to 15V, the LTM4673 supports an output voltage range of 0.6V to 3.3V for 12A channels and 0.6V to 5.5V for 5A channels. Only bulk input and output capacitors are needed.
The LTM4673s 2-wire serial interface allows outputs to be precisely margined, tuned and programmable sequenced up and down. An internal 16-bit ADC monitors and supervises input and all four output voltages, curr..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
