[原创]onsemi NCL31010完整PoE连接LED驱动器电源解决方案
关键词:IEEE 802.3bt PoE LED驱动器 onsemi NCL31010
时间:2022-07-26 16:00:06       来源:中电网
onsemi公司的NCL31010是完整PoE连接LED驱动器,集成了IEEE 802.3bt PoE−PD接口控制器,双路降压转换器和降压转换器LED驱动器. NCL31010具备了PoE系统工作时所需要的功能如检测,分类和浪涌时的电流限制.器件包含用于主3.3V系统电源和辅助电源的同步降压DC/DC转换器.此外,器件还集成电流模式降压DC/DC转换器,设计用于LED驱动器.LED驱动器支持PWM调光和高带宽模拟调光. NCL31010支持大功率应用(高达90W PoE).器件完全支持IEEE 802.3af/at 和802.3bt指标,所有权的100W+应用,支持自动分类,HV维持秩功力PWM输出(MPS),集成了3.3V降压转换器和可调降压转换器2.5V-24V,集成了高效率降压LED驱动器,可调开关频率从44.4 kHz 到1 MHz.低EMI参考设计,高精确度诊断功能以测量电压/电流,LED短路和开路保护,LED过压/欠压和过流保护,芯片过流保护,芯片和LED超温保护,结工作温度−40°C到+125°C.48引脚QFN 7x7封装,无铅和RoHS兼容.本文介绍了NCL31010主要特性,框图,典型应用电路图及其典型应用电路图材料清单,DC/DC框图, LED驱动器框图, 评估板NCL31010GEVK主要特性和应用连接图, NCL31010AASGEVB电路图和评估板NCL31010AASGEVB材料清单.
The NCL31010 is a member of the onsemi Power over Ethernet Powered Device (PoE−PD) product family and integrates an IEEE 802.3bt PoE−PD interface controller, a dual step−down converter and a buck convertor LED driver. The NCL31010 incorporates all the required functions for operation within a PoE system such as detection, classification and current limiting during the inrush phase. The NCL31010 contains synchronous step−down DC/DC converters for the main 3.3 V system supply as well as an auxiliary supply. In addit..
查看全文
