关键词:Arm Cortex-M0+ MCU 无线SoC Bluetooth ST BlueNRG-LPS
时间:2022-07-22 13:47:57 来源:中电网
ST公司的BlueNRG-LPS是超低功耗可编Bluetooth®低功耗无线SoC解决方案,嵌入了ST公司的最新的2.4GHz 无线电IP,具有超低功耗和极好的无线电性能以及无与伦比的电池寿命.器件和Bluetooth®低功耗SIG核版本5.3的点对点位址连接和蓝牙网状网络兼容,允许大规模设备网络网状以可靠方式建立. BlueNRG-LPS还适合2.4GHz专用无线电通信,接入超低等待时间的应用.器件嵌入Arm® Cortex®-M0+ MCU,能工作高达64MHz,还嵌入BlueNRG核协处理器(基于DMA),以用于Bluetooth®低能量定时关键操作.器件的数据速率为2Mbps,长距离(Coded PHY),GATT躲藏,定向(AoA/AoD),RX接收灵敏度-97 dBm @ 1 Mbps, 长距离时-104 dBm @ 125 kbps.可编输出功率高达+8dBm,数据速率支持2 Mbps, 1 Mbps, 500 kbps和125 kbps,128个物理连接,集成了平衡不平衡转换器(balun),支持外接PA和LNA,适合于需要兼容无线电频率规范ETSI EN 300 328, EN 300 440, FCC CFR47 part 15, ARIB STD-T66的系统.主要用在工业,家庭和工业自动化,资产跟踪,ID定位和实时定位系统,智能照明,健美和健身与运动,保健和消费医疗,安全/接近式,遥控,移动电话外设,PC外设和老年公寓.本文介绍了BlueNRG-LPS主要特性,框图和总线阵列图, RF框图, 时钟树图和多种应用电路,以及开发板BlueNRG-LP/BlueNRG-LPS主要特性和路图.
The BlueNRG-LPS is an ultra-low power programmable Bluetooth® Low Energy wireless SoC solution. It embeds STMicroelectronicss state-of-the-art 2.4 GHz radio IPs, optimized for ultra-low-power consumption and excellent radio performance, for unparalleled battery lifetime. It is compliant with Bluetooth® Low Energy SIG core specification version 5.3 addressing point-to-point connectivity and Bluetooth Mesh networking and allows..
分享到:
