Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Maxim MAX16731 30A 1.5MHz½µÑ¹¿ª¹ØÎÈѹÆ÷½â¾ö·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí DC£¯DCת»»Æ÷ Maxim MAX16731
ʱ¼ä£º2022-06-23 16:17:10       À´Ô´£ºÖеçÍø
Maxim¹«Ë¾µÄMAX16731ÊÇÈ«¼¯³É¸ßЧÂʽµÑ¹DC/DC¿ª¹ØÎÈѹÆ÷,¹¤×÷ÊäÈëµçÔ´´Ó2.7Vµ½16V,Êä³ö¿ÉÔÚ0.5Vµ½5.8Vµ÷Õû,Ìṩ¸ß´ï30AµÄ¸ºÔصçÁ÷.Æ÷¼þµÄ¿ª¹ØÆµÂʿɴÓ500kHz µ½ 1.5MHzÅäÖÃ,¿ÉÔڳߴçºÍÐÔÄÜÉÏÓÅ»¯Éè¼Æ. MAX16731²ÉÓù̶¨ÆµÂÊ,´øÄÚ²¿²¹³¥µÄµçÁ÷ģʽ¿ØÖÆ.IC¾ßÓÐÏȽøµÄµ÷ÖÆ·½°¸(AMS)ºÍ¿ÉÒÔÑ¡Ôñ²»Á¬ÐøµçÁ÷ģʽ(DCM)¹¤×÷,ÒÔ¸ÄÉÆÐÔÄÜ.¹¤×÷É趨ºÍÅäÖÃÌØÐÔÓÉÈý¸ö±à³ÌÒý½ÅPGM0,PGM1ºÍPGM2À´Ñ¡Ôñ. MAX16731ÓÐÄÚ²¿µÄ1.8VÏßÐÔÎÈѹÆ÷Êä³ö,¸øÕ¤¼«Çý¶¯(VCC)ºÍÄIJ¿µç·(AVDD)¹©µç.Æ÷¼þ¾ßÓжàÖÖ±£»¤,°üÀ¨ÕýºÍ¸º¹ýµçÁ÷±£»¤,Êä³ö¹ýѹ±£»¤,ºÍ³¬Î±£»¤ÒÔ±£Ö¤Â³°ôÉè¼Æ.Æ÷¼þ²ÉÓýô´ÕµÄ2.52mm x 4.89mm WLP·â×°,¹¤×÷½áÎÂ-40¡ãC µ½ +125¡ãC.Ö÷ÒªÓÃÔÚͨÐÅÉ豸,ÍøÂçÉ豸,·þÎñÆ÷ºÍ´æ´¢É豸.µã¸ºÔصçѹÎÈѹÆ÷ÒÔ¼°´æ´¢Æ÷VDDQ.±¾ÎĽéÉÜÁËMAX16731Ö÷ÒªÓÅÊÆºÍÌØÐÔ,¼ò»¯Ó¦Óõ緺͵äÐÍÓ¦Óõç·ÒÔ¼°ÆÀ¹À°åMAX16731 EVKÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The MAX16731 is a fully integrated, highly efficient, step-down DC-DC switching regulator. The regulator is able to operate from 2.7V to 16V input supplies, and the output can be adjusted from 0.5V to 5.8V, delivering up to 30A of load current.
The switching frequency of the device can be configured from 500kHz to 1.5MHz and can optimize the design in terms of size and performance.
The MAX16731 utilizes fixed frequency, current-mode control with internal compensation. The IC features advanced modulation scheme (AMS) and selectable discontinuous current mode (DCM) operation to provide improved performance. Operation settings and
configurable features can be selected..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
