Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]ADI ADPA1106 2.7GHz-3.5GHz 40Wµª»¯ïØ(GaN)¹¦ÂÊ·Å´ó·½°¸
¹Ø¼ü´Ê£ºÎÞÏßͨЊ΢²¨Í¨ÐÅ µª»¯ïØ(GaN) ADI ADPA1106
ʱ¼ä£º2022-06-21 14:06:04       À´Ô´£ºÖеçÍø
ADI¹«Ë¾µÄADPA1106Êǵª»¯ïØ(GaN)¿í´ø¹¦ÂÊ·Å´óÆ÷,Ìṩ46dBm(40W)¹¦ÂÊ,µäÐ͹¦Âʸ½¼ÓЧÂÊ(PAE),´ø¿í2.7GHzµ½3.1GHz. ƵÂÊ2.7 GHz µ½ 3.1 GHzºÍPIN=21dBmÊä³ö¹¦ÂÊPOUT=46dBm,¹¦ÂÊÔöÒæÎª25dB,СÐźÅÔöÒæÎª34.5dB. 2.7GHzµ½3.1GHzºÍPIN = 21 dBmʱµÄPAEΪ56%.µçÔ´µçѹVDD=50V, IDQ = 300 mAÕ¼¿Õ±È10%.²ÉÓÃ32Òý½Å5 mm ¡Á 5 mm LFCSP_CAV·â×°.Ö÷ÒªÓÃÔÚÆøÏóÀ×´ï,´¬ÓÃÀ×´ïºÍ¾üÓÃÀ×´ï.±¾ÎĽéÉÜÁËADPA1106Ö÷ÒªÌØÐԺ͵çÐÔÄÜÖ¸±ê,»ù±¾¿òͼÒÔ¼°46 dBm (40 W), 2.7 GHz -3.5 GHz, GaN¹¦ÂÊ·Å´óÆ÷ÆÀ¹À°åADPA1106-EVALZÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCB×°Åäͼ.
The ADPA1106 is a gallium nitride (GaN), broadband power amplifier that delivers 46 dBm (40 W) with 56% typical power added efficiency (PAE) across a bandwidth of 2.7 GHz to 3.1 GHz. The ADPA1106 has a gain flatness of ¡À0.15 dB across the 2.7 GHz to
3.1 GHz frequency range.
The ADPA1106 is ideal for pulsed applications such as marine, weather, and military radar.
The ADPA1106 comes in a 32-lead, lead frame chip scale package, premolded cavity (LFCSP_CAV) and is specified for operation from −40¡ãC to +85¡ãC.
ADPA1106Ö÷ÒªÌØÐÔ:
► Frequency range: 2.7 GHz to 3.5 GHz
► POUT: 46 dBm typical with PIN = 21 dBm at 2.7 GHz to 3.1 GHz
► Power gain: 25 dB typical with PIN = 21 dBm at 2.7 GHz to 3.1 GHz
► Small signal..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
