Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Renesas RZ£¯T2M ÐÐÒµÁìÏȵĸßÐÔÄܶ๦ÄÜMPU¿ª·¢·½°¸
¹Ø¼ü´Ê£ºArm Cortex£­R52 MCU ¹¤ÒµÂí´ï¿ØÖÆ ÒÔÌ«Íø Renesas
ʱ¼ä£º2022-06-20 16:03:24       À´Ô´£ºÖеçÍø
Renesas¹«Ë¾µÄRZ/T2MÊÇÐÐÒµÁìÏȵĸßÐÔÄܶ๦ÄÜ MPU,¿ÉʵÏÖ AC ËÅ·þϵͳºÍ¹¤Òµµç»úµÈ¹¤ÒµÉ豸µÄ¸ßËÙ´¦ÀíºÍ¸ß¾«¶È¿ØÖÆ. RZ/T2M¾ßÓÐ×î´óƵÂÊΪ 800 MHz µÄË« Arm® Cortex®-R52 ÄÚºË,¿É½øÐÐʵʱ¿ØÖÆ,¶øÇÒ»¹ÓµÓÐÄܹ»Óë CPU Ö±½ÓÁ¬½ÓµÄ´óÈÝÁ¿½ôÃÜñîºÏÄÚ´æ (576KB),ÒÔʵÏÖ¸ßÐÔÄÜʵʱ´¦Àí. RZ/T2M ÓµÓжàЭÒé±àÂëÆ÷Ó²¼þ½Ó¿Ú,¿ÉΪ A-format™,EnDat ºÍ BiSS® µÈ¸÷ÖÖ¾ø¶Ô±àÂëÆ÷ЭÒéÌṩ֧³Ö. ´ËÍâ,RZ/T2M »¹ÓµÓÐÒ»¸ö 3 ¶Ë¿ÚµÄǧÕ×ÒÔÌ«Íø½»»»»ú,¿ÉΪ TSN ±ê×¼¼° EtherCAT, PROFINET RT/IRT ºÍ EtherNet/IP µÈ¹¤ÒµÒÔÌ«ÍøÐ­ÒéÌṩ֧³Ö,¶øÎÞÐè¶îÍâµÄÒÔÌ«Íø½»»»»ú IC.MPU»¹¿ÉÒÔ½«µç»ú¿ØÖƵÄÍâÉè²¼Öõ½ÄÜÖ±½ÓÁ¬½ÓÖÁ CPU µÄ LLPP£¨µÍÑÓ³ÙÍâÉè¶Ë¿Ú£©ÉÏ,À´ÊµÏֽϵ͵ÄÑÓ³Ù·ÃÎÊ.Ö÷ÒªÓÃÔÚAC ËÅ·þϵͳºÍ¹¤Òµµç»ú.±¾ÎĽéÉÜÁËRZ/T2M MPUÖ÷ÒªÌØÐÔ, 320Òý½ÅMPUÆ÷¼þ¿òͼ, ÆÀ¹À°åRSK+Ö÷ÒªÌØÐÔºÍÖ¸±ê,ÄÚ²¿¿òͼ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The MPU is a high-performance ASSP that has dual Arm Cortex®-R52 processor with Floating-Point Unit (FPU) and NEON™. It incorporates integrated peripheral functions necessary for system configuration.
RZ/T2M MPUÖ÷ÒªÌØÐÔ:
¡ö On-chip 32-bit Arm Cortex-R52 processor
¡ñ High-speed realtime control with operating frequency of 200/400/800 MHz
¡ñ On-chip Dual/Single 32-bit Arm Cortex-R52 (revision r1p2)
¡ñ Tightly coupled memory (TCM) with ECC
¨C CPU0: 512 KB/64 KB
¨C CPU1: No support
¡ñ Instruction cache/data cache with ECC
¨C CPU0: 16 KB per cache
¨C CPU1: 32 KB per cache
¡ñ High-speed..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
