Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Maxim MAX17651 4V-60V 100mA³¬µÍ¾²Ì¬µçÁ÷ÏßÐÔÎÈѹÆ÷½â¾ö·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí ÏßÐÔÎÈѹÆ÷ Maxim MAX17651
ʱ¼ä£º2022-05-13 15:29:50       À´Ô´£ºÖеçÍø
Maxim¹«Ë¾µÄMAX17651Êdz¬µÍ¾²Ì¬Á÷¸ßѹÏßÐÔÎÈѹÆ÷,·Ç³£ÊÊÓÃÓÃÔÚ¹¤ÒµºÍµç³Ø¹©µçµÄϵͳ.Æ÷¼þµÄÊäÈëµçѹ´Ó4Vµ½60V,Ìṩ¸ß´ï100mA¸ºÔصçÁ÷,ÎÞ¸ºÔØÊ±µÄ¾²Ì¬µçÁ÷½öΪ8¦ÌA.Êä³öµçѹ´Ó0.6Vµ½58Vµçѹ·¶Î§Äڿɵ÷.·´À¡µçѹ¶Ôζȵľ«¶ÈΪ¡À2%. ¿ªÂ©µÍµçƽµÄPGOODÒý½ÅÌṩ¹¦ÂÊÁ¼ºÃÐźŸøÏµÍ³,ÒԵõ½Êä³öµçѹµÄ³É¹¦µØ¿ØÖÆ.Æ÷¼þ»¹¼¯³ÉʹÄÜÒý½Å(EN),ÔÊÐíÓû§°Ñ²¿¼þ½Óͨ»ò¹Ø±Õ.Æ÷¼þ¾ßÓÐÈȹرÕÌØÐÔ,¹Ø¶ÏоƬζȳ¬¹ý165¡ãCµÄ²¿·Ö. MAX17651¹¤×÷ÔÚ¹¤ÒµÎ¶È-40¡ãC µ½ +125¡ãC,²ÉÓÃ6Òý½Å½ô´ÕTSOTºÍ6Òý½Å(3nnx3mm)TDFN·â×°.Ö÷ÒªÓÃÔڵ͵çÁ÷¹¤ÒµµçÔ´,µç³Ø¹©µçµÄÉ豸,¿ª¹ØµçÔ´µÄºóÎÈѹÆ÷,¹«ÓüÆÁ¿ºÍÒ£¿Ø´«¸ÐÆ÷.±¾ÎĽéÉÜÁËMAX17651Ö÷ÒªÓÅÊÆºÍÌØÐÔ,¹¦ÄÜ¿òͼ, 5VÊä³öÓ¦Óõç·ͼÒÔ¼°ÆÀ¹À°åMAX17651EVKITA#Ö÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The MAX17651 ultra-low quiescent current, high-voltage linear regulator is ideal for use in industrial and battery-operated systems. The device operates from a 4V to 60V input voltage, delivers up to 100mA of load current, and consumes only 8¦ÌA of quiescent current at no load. The device consumes only 0.9¦ÌA current when in shutdown. Output voltage is adjustable in the 0.6V to 58V voltage range. Feedback voltage accuracy is ¡À2% over temperature.
An open-drain, active-low PGOOD pin provides a power-good signal to the system upon achieving successful regulation of the output voltage. The device also incorporates an enable pin (EN) that allows the user to turn the part on or off. The device has a thermal shutdown feature that shuts down the part when the die..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
